sandsquid Posted June 23, 2010 Report Share Posted June 23, 2010 I've been keeping a *** record over the last few days of my pool. However, whatever I am doing, nothing seems to work. I opened my pool this summer, and my water levels were better than expected. I had a issue with my filter automatically backwashing while it was on filter which resulted in the chemicals being wasted. Once I discovered the backwash issue and resolved it, my pool started growing alge and turned a hint of green. I instanly put in 3lbs of shock for my pool size approx. 12000 gallons. Then the water became cloudy. I am still seeing very small amounts of algea heading towards the skimmer, but I still keep fighting that issue as well as now the cloudy water issue. Total Chlorine (ppm) Free Chlorine/Bromine (ppm) pH Total Alkalinity (ppm) Total Hardness as CaCO3 (ppm) Cyanuric Acid (ppm) Date Time Notes: 1 0.5 7.5 120 500 0 6/19/2010 1630 Vacuumed @ 1600 - Added 3 lbs of Shock at 1722 (full sun) 2 1 7.4 120 250 0 6/20/2010 1430 vacuumed @ 1330 - added stabilizer condition at 1500 2 lbs. - added clarifyer @ 1530 - vacummed walls @ 1630 (full sun) 0.5 0.5 7.4 100 300 0 6/21/2010 1800 Add 12boz of liquid clorinator and 1lb of stabailzer at 1830 (overcast partly sunny) 0.5 1 7.5 120 250 0 6/22/2010 1950 Full Sun temp. 95 Quote Link to comment Share on other sites More sharing options...
brian1973 Posted July 9, 2010 Report Share Posted July 9, 2010 I've been keeping a *** record over the last few days of my pool. However, whatever I am doing, nothing seems to work. I opened my pool this summer, and my water levels were better than expected. I had a issue with my filter automatically backwashing while it was on filter which resulted in the chemicals being wasted. Once I discovered the backwash issue and resolved it, my pool started growing alge and turned a hint of green. I instanly put in 3lbs of shock for my pool size approx. 12000 gallons. Then the water became cloudy. I am still seeing very small amounts of algea heading towards the skimmer, but I still keep fighting that issue as well as now the cloudy water issue. Total Chlorine (ppm) Free Chlorine/Bromine (ppm) pH Total Alkalinity (ppm) Total Hardness as CaCO3 (ppm) Cyanuric Acid (ppm) Date Time Notes: 1 0.5 7.5 120 500 0 6/19/2010 1630 Vacuumed @ 1600 - Added 3 lbs of Shock at 1722 (full sun) 2 1 7.4 120 250 0 6/20/2010 1430 vacuumed @ 1330 - added stabilizer condition at 1500 2 lbs. - added clarifyer @ 1530 - vacummed walls @ 1630 (full sun) 0.5 0.5 7.4 100 300 0 6/21/2010 1800 Add 12boz of liquid clorinator and 1lb of stabailzer at 1830 (overcast partly sunny) 0.5 1 7.5 120 250 0 6/22/2010 1950 Full Sun temp. 95 Quote Link to comment Share on other sites More sharing options...
brian1973 Posted July 9, 2010 Report Share Posted July 9, 2010 use a quart of algaecide 60% the whole thing do not worry about the ph level or alkalinity till the water is clear then i would add 3 gallons of liquid chlorine to the pool followed by 4 lbs of shock the liquid chlorine will bring the level up high to kill any algaecide but it will come back down overnite if you listen to this you should see a big difference overnite also backwash pool if sandfilter 2 to 3 trimes daily untill pool water is clear then ajust alkalinity level if needed wait 5 hours and ajust ph if needed Quote Link to comment Share on other sites More sharing options...
kb62591 Posted September 14, 2010 Report Share Posted September 14, 2010 You certainly do not seem like a newbie to me. I love this forum and the help people are offering one another. Hope I can be of value some day. -Kevin Quote Link to comment Share on other sites More sharing options...
