Thanks Polyvue. My current pressure at the filter is 10 PSI. When it gets to about 20 PSI, I typically backwash it.
I am using HTH Shock 'n Swim #3 with CALCIUM HYPOCHLORITE 47.6%, OTHER INGREDIENTS 52.4%, TOTAL 100%, MINIMUM AVAILABLE CHLORINE 45%. (43% Potassium Monopersulfate)
(that's all I can find for ingredients)
I use HTH Liquid Chlorinator with SODIUM HYPOCHLORITE 10%, OTHER 90%, once the pool gets balanced, then I will use the HTH hockey pucks.
I believe I am getting a CYA reading, however it appears to be very low and doesn't even come close to the colors on the strips. I will try a different brand of test strips to see if there is any difference. I am not sure why I wouldn't be getting a CYA reading, or why it would be very low.
I went and checked on the pool this morning first thing. I do not see any more algae at the surface like I had been seeing. I think I may have won that battle.
