southportmom Posted May 26, 2010 Report Share Posted May 26, 2010 Purchased and installed a 15x30" oval above-ground pool. Which is best...chlorine tablets, liquid or automatic in-line chlorinator ? Which appreciate any feedback. Quote Link to comment Share on other sites More sharing options...
polyvue Posted June 6, 2010 Report Share Posted June 6, 2010 Purchased and installed a 15x30" oval above-ground pool. Which is best...chlorine tablets, liquid or automatic in-line chlorinator ? Which appreciate any feedback. Tablets and in-line chlorinators use chlorine compounds (usually Di-Chlor or Tri-chlor) that will add not only chlorine but stablizer to the pool. Some stabilizer (cyanuric acid or CYA) is good; too much can be bad. Use a good test kit (Taylor K-2006 or equivalent) to measure the CYA and keep it in the 30-60 ppm range and chlorine levels at about 8-10% of CYA. E.g. If CYA = 50 ppm maintain Free Chlorine level of 4 -5 ppm. Liquid chlorine, in the form of 12% pool chlorine or 6% bleach (e.g. Clorox unscented), is the most straightforward method to sanitize but not necessarily the most convenient. If you don't use a pool cover you may have to add chlorine every few days. (Without any stabilizer, you'd have to add liquid chlorine every night.) Quote Link to comment Share on other sites More sharing options...
