JeffL2 Posted May 19, 2010 Report Share Posted May 19, 2010 Is there something special about pool plaster? A few years ago I was using plaster to patch a wall, and seem to recall that if I got it wet after it hardened, the plaster patch would soften up again. So I was wondering how pool plaster stays hard. Quote Link to comment Share on other sites More sharing options...
geeman Posted May 20, 2010 Report Share Posted May 20, 2010 You probably used spackle, which will get soft if re-wetted. Plaster is a mixture of cement and aggregate and most often calcium as an accelerator - there is a chemical reaction making it hard. Wetting of plaster only enhances the cure. Quote Link to comment Share on other sites More sharing options...
JeffL2 Posted May 21, 2010 Author Report Share Posted May 21, 2010 Thanks geeman. You're are probably right. I did some repair work a few days ago for the first time in a long time, and that is what brought it to mind. I know I used plaster of paris this time (and didn't get it wet afterwards), but almost all the time in the past, I did use spackle, so I probably just got my experiences confused. Quote Link to comment Share on other sites More sharing options...
