shintao Posted May 8, 2010 Report Share Posted May 8, 2010 Hi! I am buying a house with a pool and would like to know what the components are. There is something wrong with the pump, and I will have a pool inspector who will look at it. The pool is drained and looking ugly right now. What is the Grey & Black pots? And I guess the pump & motor, and then the white box. Is the box a timer or just a fuse box? I plan to make a sun cover over the entire unit, since it is plastic materials. Quote Link to comment Share on other sites More sharing options...
polyvue Posted May 8, 2010 Report Share Posted May 8, 2010 Hi! I am buying a house with a pool and would like to know what the components are. There is something wrong with the pump, and I will have a pool inspector who will look at it. The pool is drained and looking ugly right now. What is the Grey & Black pots? And I guess the pump & motor, and then the white box. Is the box a timer or just a fuse box? I plan to make a sun cover over the entire unit, since it is plastic materials. Gas heater; Sand Filter; Jandy valve with split return below and to the left; the white box could be a controller or a subpanel, possibly with timer; Jandy valve (suction side) with joined pipes entering main circulation pump (it has a clear lid over the pump basket). Can't tell for sure from the photo but the two pipes adjacent to the downspout may lead to solar panels. 2nd photo: Dirty water -- However, judging from the photo, the deck, coping, tile and plaster look good. Quote Link to comment Share on other sites More sharing options...
AFiremanFirst Posted May 8, 2010 Report Share Posted May 8, 2010 I'm not quick to call that a sand filter, could also bd a DE filter, or a cartridge (the black unit) The grey is definately a gas heater. The white box is your controller probably a subpanel for your indoor contoller, you've also got a blower for your hot tub behind the white box. Quote Link to comment Share on other sites More sharing options...
shintao Posted May 9, 2010 Author Report Share Posted May 9, 2010 Gas heater; Sand Filter; Jandy valve with split return below and to the left; the white box could be a controller or a subpanel, possibly with timer; Jandy valve (suction side) with joined pipes entering main circulation pump (it has a clear lid over the pump basket). Can't tell for sure from the photo but the two pipes adjacent to the downspout may lead to solar panels. 2nd photo: Dirty water -- However, judging from the photo, the deck, coping, tile and plaster look good. Yes, there are solar panels on the roof feeding down there to the grey gas heater. I didn't notice a gas line, but there maybe one there. Ok, I do apreciate you peoples help and will go do some searching on those components. I don't have the name of the pool builders yet, who may have those exact items and instruction manuals. I would recommend this site have a small list of terms, so newbies like me know what you mean. Like I recognize DE as the earth stuff, but some other shorts I don't. Thank you & I will be around. Quote Link to comment Share on other sites More sharing options...
Pathfinder Posted May 9, 2010 Report Share Posted May 9, 2010 The grey one is your heater the gas pipe is right in front of the heater in pic. The Black is either a System 3 Cartridge or D.E. but im inclined to say its a cartridge since there is no backwash line visible in the pic. For manuals go to www.starite.com Quote Link to comment Share on other sites More sharing options...
poolguyinsc Posted May 11, 2010 Report Share Posted May 11, 2010 Looks like a Sta-Rite Cartridge filter with a leaky pressure gauge, a Sta-Rite heater, and a Sta-Rite pump. Quote Link to comment Share on other sites More sharing options...
