Larry K. Posted March 7, 2010 Report Share Posted March 7, 2010 I have two possible locations for a tub (92x92): 1. Outside under a pergola on a gravel pad. 2. Inside a large screened in porch on an existing cement pad (the pad is about 1/4 inch off level away from the house). On a personal level there are pros and cons for both, but what about that 1/4 inch? Thanks... Quote Link to comment Share on other sites More sharing options...
ps558 Posted March 7, 2010 Report Share Posted March 7, 2010 I have two possible locations for a tub (92x92): 1. Outside under a pergola on a gravel pad. 2. Inside a large screened in porch on an existing cement pad (the pad is about 1/4 inch off level away from the house). On a personal level there are pros and cons for both, but what about that 1/4 inch? Thanks... The 1/4 inch won't be bad if the filter area is on the side with lowest point on the pad. We have done this and never had a problem. Also think about air circulation if going in the screened porch. It will make alot of moisture Quote Link to comment Share on other sites More sharing options...
Dustin Golden Posted March 8, 2010 Report Share Posted March 8, 2010 I used your second option and never got problem on it. Try this one if it suited as per your area. Quote Link to comment Share on other sites More sharing options...
bart6453 Posted March 8, 2010 Report Share Posted March 8, 2010 Actually having a 1/4" drop is going to help you out. If you splash water over the sides it will run away from the house. Secondarily and more importantly, if it were flat and you had a torrential rain your could flood your basement. No matter the situation a reasonable elevation drop is required for surfaces adjacent to your home. If the equipment is not capable of installation with said elevation drop....you shouldn't have it that close to your house....no matter what it is. Quote Link to comment Share on other sites More sharing options...
