t_brown Posted January 15, 2010 Report Share Posted January 15, 2010 I have a 2001 Cal Spa that the circulation pump motor went out on. I am having all kinds of trouble finding a replacement motor for it. The plate on the motor says that it is a 230V Single Phase Single Speed 1725 RPM 2.9A GE Motor. Can someone please direct me to a place where I can find a similar motor? Everything I have found has a higher RPM and a higher amperage. I don’t know if this would have any ill effects to the system. Thanks a lot for any help you can give Quote Link to comment Share on other sites More sharing options...
ps558 Posted January 16, 2010 Report Share Posted January 16, 2010 I have a 2001 Cal Spa that the circulation pump motor went out on. I am having all kinds of trouble finding a replacement motor for it. The plate on the motor says that it is a 230V Single Phase Single Speed 1725 RPM 2.9A GE Motor. Can someone please direct me to a place where I can find a similar motor? Everything I have found has a higher RPM and a higher amperage. I don’t know if this would have any ill effects to the system. Thanks a lot for any help you can give Is this the pump you are looking for http://www.lwico.net/cart/products/Circ_Ma...1_sp-203-1.html I had to replace one these pumps for a customer and found it was easier to replace the entire pump. You have to take note if the pipe going to the heater is in the middle or offset. If you can give me the HP rating I might be able to find a AO Smith motor these are not standard motors to find Is there any Ao Smith motor shops near you or retailers Quote Link to comment Share on other sites More sharing options...
t_brown Posted January 16, 2010 Author Report Share Posted January 16, 2010 I have a 2001 Cal Spa that the circulation pump motor went out on. I am having all kinds of trouble finding a replacement motor for it. The plate on the motor says that it is a 230V Single Phase Single Speed 1725 RPM 2.9A GE Motor. Can someone please direct me to a place where I can find a similar motor? Everything I have found has a higher RPM and a higher amperage. I don’t know if this would have any ill effects to the system. Thanks a lot for any help you can give Is this the pump you are looking for http://www.lwico.net/cart/products/Circ_Ma...1_sp-203-1.html I had to replace one these pumps for a customer and found it was easier to replace the entire pump. You have to take note if the pipe going to the heater is in the middle or offset. If you can give me the HP rating I might be able to find a AO Smith motor these are not standard motors to find Is there any Ao Smith motor shops near you or retailers No, that isnt the pump that we have. I called emotorstore.com and found out a little more info about the motor. it is a 1/4 hp with a 56Y frame. She said that GE no longer makes that motor and there wasnt a replacement listed and she wasnt able to find an AO replacement either. It is starting to look like i will just have to replace the whole pump Quote Link to comment Share on other sites More sharing options...
ps558 Posted January 16, 2010 Report Share Posted January 16, 2010 I have a 2001 Cal Spa that the circulation pump motor went out on. I am having all kinds of trouble finding a replacement motor for it. The plate on the motor says that it is a 230V Single Phase Single Speed 1725 RPM 2.9A GE Motor. Can someone please direct me to a place where I can find a similar motor? Everything I have found has a higher RPM and a higher amperage. I don’t know if this would have any ill effects to the system. Thanks a lot for any help you can give Is this the pump you are looking for http://www.lwico.net/cart/products/Circ_Ma...1_sp-203-1.html I had to replace one these pumps for a customer and found it was easier to replace the entire pump. You have to take note if the pipe going to the heater is in the middle or offset. If you can give me the HP rating I might be able to find a AO Smith motor these are not standard motors to find Is there any Ao Smith motor shops near you or retailers No, that isnt the pump that we have. I called emotorstore.com and found out a little more info about the motor. it is a 1/4 hp with a 56Y frame. She said that GE no longer makes that motor and there wasnt a replacement listed and she wasnt able to find an AO replacement either. It is starting to look like i will just have to replace the whole pump I can't find a replacement either in Ao Smith's catalog. Since the motor is hard to find it might come out the same price and a complete pump. Did you try to contact Cal Spa for a part number and a dealer Quote Link to comment Share on other sites More sharing options...
t_brown Posted January 16, 2010 Author Report Share Posted January 16, 2010 I still havent been able to find a replacement motor so I think i will just get a new pump. What should i be looking for as far as a replacement goes? Are most circulation pumps pretty similar? The one that i have is offset. Thats about all i know. Thanks again for the help Quote Link to comment Share on other sites More sharing options...
ps558 Posted January 17, 2010 Report Share Posted January 17, 2010 I still havent been able to find a replacement motor so I think i will just get a new pump. What should i be looking for as far as a replacement goes? Are most circulation pumps pretty similar? The one that i have is offset. Thats about all i know. Thanks again for the help The one you need are all pretty much the same. The motor is smaller than a jet pump motor. here is a pic of offset discharge. http://www.amerimerc.com/spa-pump~spa-flo.htm Some cal spa pumps the discharge comes out the side not the top. Most pumps are sold with it facing up. This is a easy problem to solve. There are 4 bolt heads the hold the wet end on. Loosen all four and turn the wet end to direction you need and retighten. It fall off the motor because the impeller is still threaded to the shaft Quote Link to comment Share on other sites More sharing options...
t_brown Posted January 17, 2010 Author Report Share Posted January 17, 2010 That wet end looks just like the one we have, discharge off center on the top. One main difference i see is that the 230v one is 2HP, the motor that we had was only 1/4hp. Will that cause any problems? Possibly running water through the heater too quickly? Quote Link to comment Share on other sites More sharing options...
ps558 Posted January 18, 2010 Report Share Posted January 18, 2010 That wet end looks just like the one we have, discharge off center on the top. One main difference i see is that the 230v one is 2HP, the motor that we had was only 1/4hp. Will that cause any problems? Possibly running water through the heater too quickly? Yeah you do not want a two hp pump. Here is a link for a 1/15 hp at the bottom of page http://www.poolandspa.com/catalog/product004138000536.cfm Quote Link to comment Share on other sites More sharing options...
t_brown Posted January 20, 2010 Author Report Share Posted January 20, 2010 Will that pump not be too small? I have completely given up on finding a replacement motor, and the customer service at Cal Spas is TERRIBLE. they won't have any replacement pumps in for 2-3 weeks. I would like to try and get something in the next couple of days. if you think that 1/15 hp pump will work, i will give that a shot. Thanks a lot! Quote Link to comment Share on other sites More sharing options...
ps558 Posted January 21, 2010 Report Share Posted January 21, 2010 Will that pump not be too small? I have completely given up on finding a replacement motor, and the customer service at Cal Spas is TERRIBLE. they won't have any replacement pumps in for 2-3 weeks. I would like to try and get something in the next couple of days. if you think that 1/15 hp pump will work, i will give that a shot. Thanks a lot! I know this place has your exact replacement but they do not sell to the public. Here is link to find a retailer that has a account with them pick by state http://spaparts.com/findreseller.htm Quote Link to comment Share on other sites More sharing options...
