grunt66 Posted November 25, 2009 Report Share Posted November 25, 2009 I am using the Nature 2 stick with the MPS shock in my Jacuzzi J-480. The spa came with a start up kit that included the AquaChek test strips to check the MPS levels. I purchased some nature 2 test strips to keep in reserve for when the AquaChek run out. Here is the issue I tried both test strips while checking the MPS levels and the AquaChek states the levels are good and the Nature 2 states it is low. I use the Taylor test kit for all other readings in the spa. I know that test strips are not that accurate but I know of no other test to check MPS levels. So does anybody have any input on which test strips would be the best ones to follow and purchase in the future. Thanks Quote Link to comment Share on other sites More sharing options...
quantumchromodynamics Posted November 26, 2009 Report Share Posted November 26, 2009 You could try the LaMotte test strips. You could also use the Taylor FAS DPD test. If you use chlorine, you would want to get the Taylor K-2041 or K-2042 to selectively determine free chlorine, combined chlorine and MPS. See the instructions here. Quote Link to comment Share on other sites More sharing options...
