lkneisler Posted November 8, 2009 Report Share Posted November 8, 2009 After disconnecting the little air tube, how do you get the jet off/out? I thought it was supposed to be "so easy". Quote Link to comment Share on other sites More sharing options...
Dan.The.Spa.Man Posted November 8, 2009 Report Share Posted November 8, 2009 After disconnecting the little air tube, how do you get the jet off/out? I thought it was supposed to be "so easy". It is, it just unscrews. Make sure you grab it by the base close to where it screws in, otherwise the whole jet just twists and it may not be as easy. Quote Link to comment Share on other sites More sharing options...
lkneisler Posted November 8, 2009 Author Report Share Posted November 8, 2009 It is, it just unscrews. Make sure you grab it by the base close to where it screws in, otherwise the whole jet just twists and it may not be as easy. Thank you Dan.The.Spa.Man! I broke it It must be really stuck cos I couldn't get it to budge at all. It did twist right off in my hand too! So now the end is stuck in there. I'll try some vice grips or something creative. Thanks again! Lori Quote Link to comment Share on other sites More sharing options...
