Heater Wont Turn Off Once Temperature Is Reached
TwistC3
turned the breaker on to get the spa heated and running and the heater ran laa night and day. It did not feel too hot so i think it reached them temperatur. I dont think it was the filter running because water was coming out of one of the jets. Any ideas or advice as to where i should start the trouble shooting? Thanks.
Im not sure I understand what your question and/or problem is.
What make, model and age is your tub?
Did it get to temp or not?
Is it 110 or 220V?
My tub has a full time circulation pump that pulls water through the filter and the heater kicks on and off as needed. This comes from one jet near the bottom of the tub.
Give us the above info and a little clearer question and Im sure some of the more experienced people on here will be along and give you the needed support!
