rayman Posted September 12, 2009 Report Share Posted September 12, 2009 I just moved my tub ten feet when I tried to re start her the gfi breaker keeps kicking off. I know it's on the 120v board side because it only kicks off when the netural is wired in . Worked fine before, now it won't?? Is the board blown? seems like the rl4 high limit relay is the issue any ideas Thanks in advace Gerry B. Quote Link to comment Share on other sites More sharing options...
Hotrod Posted September 13, 2009 Report Share Posted September 13, 2009 I just moved my tub ten feet when I tried to re start her the gfi breaker keeps kicking off. I know it's on the 120v board side because it only kicks off when the netural is wired in . Worked fine before, now it won't?? Is the board blown? seems like the rl4 high limit relay is the issue any ideas Thanks in advace Gerry B. I dont think its the board, double check your connections. Quote Link to comment Share on other sites More sharing options...
