bobm Posted June 23, 2009 Report Share Posted June 23, 2009 hydropool pushes water through a filter and they say the filter lasts up to 2 years sundance uses the nature 2 system which they say is the best for least amount of chemicals used and the 2 stage filter lasts up to 8 months d1 says their system is the best.... one says full foam insulation is best the other says trapped air is best. sundance says their jets are better as there is no moving parts and dont need to be replaced as often. it seems to go on and on with claims..even the warranties,d1 says 5 years on the plumbing but on the website shows the ozone plumbing exempt ..2 years.. i am starting to lean more on the side of hydropool right now. just that they seem to be a smaller company, as there is not alot of talk about them on the forums.. and thats where there is good info on hot tubs.. Quote Link to comment Share on other sites More sharing options...
canadianrepairman Posted June 24, 2009 Report Share Posted June 24, 2009 hydropool pushes water through a filter and they say the filter lasts up to 2 years sundance uses the nature 2 system which they say is the best for least amount of chemicals used and the 2 stage filter lasts up to 8 months d1 says their system is the best.... one says full foam insulation is best the other says trapped air is best. sundance says their jets are better as there is no moving parts and dont need to be replaced as often. it seems to go on and on with claims..even the warranties,d1 says 5 years on the plumbing but on the website shows the ozone plumbing exempt ..2 years.. i am starting to lean more on the side of hydropool right now. just that they seem to be a smaller company, as there is not alot of talk about them on the forums.. and thats where there is good info on hot tubs.. if your trying to decide on what spa to buy, before your get caught up on which spa is best (opinions vary, including mine) 1. check your local BBB 2. check how long the dealer has been in business, and 3. choose which dealer your most comfortable with. you could by the best spa and have the worst dealer and when something goes wrong its going to feel like the worst tub ever. Quote Link to comment Share on other sites More sharing options...
