Bill H Posted April 18, 2009 Report Share Posted April 18, 2009 This pump has stopped working ... it just hums and gets hot. The shaft has rusted (I can manually move it) and there is also a seal leak so I'm thinking of replacing the whole assembly. Can anyone tell me the place to go for a replacement? I'm not sure what HP this pump is but have all the other specs from its label. Magnetek part 7-193229-01, type CXSM, 230 volt, frame X48Y The wet end (I think) is a Sundance Theraflo model 6500-264 ... Thanks for your help. Quote Link to comment Share on other sites More sharing options...
ps558 Posted April 19, 2009 Report Share Posted April 19, 2009 This pump has stopped working ... it just hums and gets hot. The shaft has rusted (I can manually move it) and there is also a seal leak so I'm thinking of replacing the whole assembly. Can anyone tell me the place to go for a replacement? I'm not sure what HP this pump is but have all the other specs from its label. Magnetek part 7-193229-01, type CXSM, 230 volt, frame X48Y The wet end (I think) is a Sundance Theraflo model 6500-264 ... Thanks for your help. Here is a link to some pumps, i do not know nothing about this online retailer http://www.spaandpoolsource.com/sundancesp...o1997-1998.aspx You have to make sure you match the volts, which you have. Also if it is a single or 2 speed pump Quote Link to comment Share on other sites More sharing options...
