Bluey Posted April 15, 2009 Report Share Posted April 15, 2009 Does anyone know how to pull the ends off an UltraJet 2 speed pump motor (MOD M215007403 - although they're almost certainly all the same in this respect) ? I have removed the pump itself, and the long screws holding the two ends on the motor. But the ends, although free will not easily come off the motor shaft, and so allowing access to the inside of the motor. Is there a press fit in there somewhere, or do I just need to apply more force (which Im reluctant to do until I know if its a press fit or not). Please note, Im dismantling the pump MOTOR itself not the pump. (Well two in fact ... its a long story) Bluey Quote Link to comment Share on other sites More sharing options...
Pathfinder Posted April 15, 2009 Report Share Posted April 15, 2009 Regardless of motor change you still have to separate the wet end in 2 then unthread the impeller which is always fun . You should change the seals as well. Quote Link to comment Share on other sites More sharing options...
