Symore Posted April 5, 2009 Report Share Posted April 5, 2009 Hello, I started to drain my Grandee with both hoses attached to each drain fitting. As it was draining I noticed water leaking out from under the accsess cover. When I took the cover off I noticed a tube with water coming out of it. I do not know where this end of the tube goes. It is attached to the outlet pipe and the other end with the water coming out was just hanging there. Does anyone know what this tube is for and where it goes? Thanks Quote Link to comment Share on other sites More sharing options...
Symore Posted April 5, 2009 Author Report Share Posted April 5, 2009 Hello again; Just found out it is my ozonator tube. For some reason it had some sort of connector joining it togeather. I disconnected it at the panel and capped it off. Do I need the ozonator just seems like one more thing to go wrong. Quote Link to comment Share on other sites More sharing options...
