Raegor Posted March 25, 2009 Report Share Posted March 25, 2009 I have a HS Vanguard which has the 24hr cirulation pump w/ ozone and water feature on the same pump. I have been turning off the water feature when covered/not in use but I'm wondering if leaving it on will create more circulation? Or does it not matter? Quote Link to comment Share on other sites More sharing options...
JerimiahR Posted March 25, 2009 Report Share Posted March 25, 2009 I have a HS Vanguard which has the 24hr cirulation pump w/ ozone and water feature on the same pump. I have been turning off the water feature when covered/not in use but I'm wondering if leaving it on will create more circulation? Or does it not matter? It's actually best to turn it off as you have been doing. You'll get better circulation with that water feature off. Turn that water feature on all the way sometime, and watch the amount of ozone bubbles you get coming out of the bottom of the spa. Then turn that thing off. You'll see a change in water flow from the bottom there. The idea is to allow the warm water to enter from the bottom, and then to be pulled back in through the filter area (top). This will create better overall circulation than all surface movement. Plus, some argue it may save on the wear n tear on the circulation pump to leave the little waterfall off. Quote Link to comment Share on other sites More sharing options...
Raegor Posted March 26, 2009 Author Report Share Posted March 26, 2009 Thanks for the quick response, I'll keep turning it off like I have been. I have another question that I pm'd you. Quote Link to comment Share on other sites More sharing options...
