gcaLuna13 Posted February 24, 2009 Report Share Posted February 24, 2009 I lost my keys backyard tub manual. What do these stand for (on my digital readout)? SL ST CL And these settings: F2 F4 F6 F8 Thanks, Luna13 Quote Link to comment Share on other sites More sharing options...
gcaLuna13 Posted March 24, 2009 Author Report Share Posted March 24, 2009 Anybody have a "Keys" ? Quote Link to comment Share on other sites More sharing options...
usguys spa service Posted March 24, 2009 Report Share Posted March 24, 2009 sl= sleep mode temp will drop 20 deg below set temp and maintian. if temp is set at 100 deg heater will not come on until spa temp reaches 80 deg then maintain 80 eg. use if going on vacation st= standard mode will maintain set temp ec= econo mode spa will only heat to set temp during the filter cycle if set at f2 heater will run 2 hours out of every 12 hour period. if filter cycle starts at 8 am spa will heat from 8am til 10 am and won't come on again until 8pm.so if you get home at 5 and want to go in spa temp might be a few degrees below desired temp.to set time to start filter cycle shut off breaker and restart spa at desired time. if you use spa at 5pm everyday reset breaker at 4:30. remember spa will run next filter cycle at 4:30 am noise may be a concern for you or your neighbours depending where spa is located f2 (most spas normal bather load)=spa will filter water 2 hours out of every 12 hour period. 4 hours out of every 24 hour period f4= spa will filter for 4 hours out of 12 hour period. 8 out of 24. f6=6 out of 12 12 out of 24 0 Quote Link to comment Share on other sites More sharing options...
gcaLuna13 Posted March 25, 2009 Author Report Share Posted March 25, 2009 Ah yes, Very Cool Thanks much. Luna13 Quote Link to comment Share on other sites More sharing options...
spafigher Posted May 11, 2009 Report Share Posted May 11, 2009 Does anyone have a trick to getting the control panel into program mode. I have four buttons. Jet Light Up arrow Quote Link to comment Share on other sites More sharing options...
Hotrod Posted May 12, 2009 Report Share Posted May 12, 2009 Does anyone have a trick to getting the control panel into program mode. I have four buttons. Jet Light Up arrow temp arrow and light with in 3 sec I think. Quote Link to comment Share on other sites More sharing options...
