mmitchell Posted August 16, 2006 Report Share Posted August 16, 2006 I have read a lot of the posts here and I am wondering if I am making the wrong choice about getting a fiberglass pool. It seems like a lot of people have had cracks and problems with contractors. What do you think I should do? Vinyl or fiberglass? Quote Link to comment Share on other sites More sharing options...
Jim_The_Jim Posted August 16, 2006 Report Share Posted August 16, 2006 I have read a lot of the posts here and I am wondering if I am making the wrong choice about getting a fiberglass pool. It seems like a lot of people have had cracks and problems with contractors. What do you think I should do? Vinyl or fiberglass? I have worked with both types. If you are a do it yourselfer, then vinyl liner is somthing you can change yourself after about 10 years. The fiberglass will requier a resurface after about 10 years. That is a complete sanding and re prime and re paint with epoxie paint. I would check into those costs in your area. We used to charge about 1000 to 1200 for a new liner installed in a 18 x 32 pool. The resurface may be more. If the fiberglass pool is not set properly, it can crack. I would read up on it or contact others on how it is done properly in your area. Quote Link to comment Share on other sites More sharing options...
mmitchell Posted August 16, 2006 Author Report Share Posted August 16, 2006 I have worked with both types. If you are a do it yourselfer, then vinyl liner is somthing you can change yourself after about 10 years. The fiberglass will requier a resurface after about 10 years. That is a complete sanding and re prime and re paint with epoxie paint. I would check into those costs in your area. We used to charge about 1000 to 1200 for a new liner installed in a 18 x 32 pool. The resurface may be more. If the fiberglass pool is not set properly, it can crack. I would read up on it or contact others on how it is done properly in your area. Thanks for the reply. I have never heard of a fiberglass needing resurfacing. I will make sure I ask... Quote Link to comment Share on other sites More sharing options...
