sjt2900 Posted August 29, 2008 Report Share Posted August 29, 2008 How soon after adding dichlor, clarifier or mps is it ok to use the tub? Quote Link to comment Share on other sites More sharing options...
Hillbilly Hot Tub Posted August 30, 2008 Report Share Posted August 30, 2008 When the sanitizer reading becomes in the ok range for chlorine. Mps you can safely use the tub 15 minutes after applying. Quote Link to comment Share on other sites More sharing options...
elmo Posted August 31, 2008 Report Share Posted August 31, 2008 When the sanitizer reading becomes in the ok range for chlorine. Mps you can safely use the tub 15 minutes after applying. What about when you add "ph up" or "ph down"? How long do you have to wait to soak? Thanks! Quote Link to comment Share on other sites More sharing options...
Vermonter Posted September 1, 2008 Report Share Posted September 1, 2008 When the sanitizer reading becomes in the ok range for chlorine. Mps you can safely use the tub 15 minutes after applying. What about when you add "ph up" or "ph down"? How long do you have to wait to soak? Thanks! Generally a 1/2 hour to be safe, as long as the pH and TA aren't way out of acceptable ranges after adding these products. Quote Link to comment Share on other sites More sharing options...
