wolfgang Posted August 3, 2006 Report Share Posted August 3, 2006 I need help in the worst way! Fiberglass pool...18,200 gallons I'm tired of playing the yo-yo game trying to get the TA and PH in line. My TA was at 150 3 days ago and the ph was at 6.8. My local pool store told me to add Muratic Acid to get the TA in line first, which I did. (Added about 2 quarts over the period of 24 hours) So, I got the TA to the 100 mark and started adding PH up to get the PH to at least 7.2 Finally after adding 6 lbs over the course of 24 hours got the PH all set to the 7.2 mark. But......tested the water this morning and I'm right back where I started....except even worse! So darned frustrating! I'm now reading 170 TA and only 6.8 PH. HELP ME! :wacko Quote Link to comment Share on other sites More sharing options...
dynamictiger Posted December 1, 2006 Report Share Posted December 1, 2006 This post reads like bore water is being used to fill the pool. Have you checked the results of your test kit against a sample taken to the pool store? Perhaps your test kit is giving you errors in it's readings. If the results you are desribing are defintely correct, then try the following. 1: Turn your eyeballs upwards so the surface of the pool is distrubed as much as possible 2: Run the pool plant 24 hours a day for 5 days without any cover on the pool 3: Repeat the testing and post the results There is another step we can take to get this right, however the above normally works. HTH Quote Link to comment Share on other sites More sharing options...
