Andrew61987 Posted June 17, 2008 Report Share Posted June 17, 2008 Once a spa runs out of bromine and gets cant-see-the-bottom-cloudy (FYI this is happening in a matter of hours, usually after it gets used while low on bromine) is there any easy way to clear that water up? Or is it just easier at that point to drain it and put fresh water? Quote Link to comment Share on other sites More sharing options...
Whoneedsavacation Posted June 17, 2008 Report Share Posted June 17, 2008 Once a spa runs out of bromine and gets cant-see-the-bottom-cloudy (FYI this is happening in a matter of hours, usually after it gets used while low on bromine) is there any easy way to clear that water up? Or is it just easier at that point to drain it and put fresh water? Done that twice. It will clear up! Bring the bromine level back up, shock aggressively for several days, and the water will get back to normal. Rinsing the filter may help, too, as may adding clarifiers to help filter out the "dead soldiers". I would NOT use the tub if hte bromine level falls below the safe range until the level had been back up for a while. Are you using tablets in a floater or a bank & shock system? Quote Link to comment Share on other sites More sharing options...
