Andrew61987
19 -
Andrew61987's Achievements
Non Copper Algaecide And Borox
Andrew61987 replied to Andrew61987's topic in Swimming Pool Water Chemistry
The algae coincided with a whole bunch of dirt that went into the pool from some construction being done next door. Does that make sense? Do you anticipate the foaming and bad smells from algaecide to disapear? Local pool store says my CYA is 35 but I don't necessarily trust them. Having lots of trouble finding a stand alone CYA test kit. -
Been having problems with my pool recently. pH was 6.8, ALK was ~120, and the pool was green with algae all over the sides, even though I cleaned it all off just a couple days before. Chlorine stays at 5+ ppm always. Dichlor. I added 4 boxes of Borax to bring pH at about 7.2 and 4 ounces of Super Algae Stop (which is algaecide w/o copper). Algae was gone after 12 hours, but now the water is bluish white, I would almost call it "milky" although I can still see the bottom. The algaecide made the water smell rather bad and taste funny too. Will this go away soon? It's been a couple days. It also has a foaming problem now too when I kick around in the water. Is this the algaecide or Borax? 20,000 gal pool temp: 82 degrees F Remains covered except when in use. Another question about borates: I added 4 boxes several months ago, and I added another 4 ounces the last couple days. Do borates dissipate from the pool? Or am I getting close to the point where I should stop adding borax and use soda ash instead?
6 Lbs Baking Soda And No Change In Ph?
Thanks Richard... I thought I Had to go back to Pool School I stand corrected, sorry mumpelnc. -
Baking Soda raises Alk, Borax raises Ph.. Baking soda will raise pH just fine. Something else must be up. -
20,000 in ground vinyl liner pool. Alk is about 110 - 120. I have been keeping the chlorine level fairly high, probably between about 5 - 10 ppm over the last 3 or 4 weeks or so to combat some algae. The pH is 6.8. I added a couple pounds of baking soda which was all I had and after 24 hours observed no change. Added a few pounds more and now it has been several days and the pH has not budged. Any suggestions?
Alkalinity Test Blue>yellow After Baking Soda?
Andrew61987 replied to Andrew61987's topic in Hot Tub Water Chemistry
Wow, and to think I was using it this whole time. Not sure how that happened so quick. Is it possible the low pH was causing the sanitizing tablets to dissolve quicker than normal resulting in a high concentration of sanitizer? -
Andrew61987 posted a topic in Hot Tub Water Chemistry
2 days ago I tested my spa water with the typical Taylor titration type alkalinity test. Upon adding the indicator solution the sample immediately turned red before I even added a drop of sulfuric acid. I took this as TA = 0. I then tested the pH and it was off the chart low. I sprinkled in some baking soda to remedy the problem and tested it an hour, as well as 12 hours later. Testing the alkalinity after the baking soda resulted in a LIGHT BLUE (instead of the usual green) sample after adding the TA Indicator solution, and 8 drops of sulfuric it turned yellow (instead of the usual red). I took this as TA = 80 which is acceptable, however I have never seen these weird colors in the alkalinity test before. What does this mean? -
My dad and I notice that when I clean out the cartridge filter the water seems to go cloudy for a little while. Does the dirt and oil contained in a slightly dirty filter aid in further cleaning of the water by effectively increasing the density of the mesh? Or is this the work of some other phenomenon? (20,000 in ground vinyl lined pool, using dichlor)
I notice the EXACT same thing. Sorry I don't have an answer, but I am interested in hearing one.
Best Reccomendation On Cleaning Tub
Andrew61987 replied to benalexe's topic in Hot Tub Water Chemistry
Bail out as much of the water as you can, but don't tweak out trying to get every last puddle. Then go to a wet/dry vac and suck out the rest of the water and leaves and crap as you continue to rinse down the sides to make sure you get all the large heavy solids like dirt and sand. Fill it up all the way and run it for a couple days while you sanitize it to death. Maintain a high bromine level and shock the **** out of it. Clean the filter AT LEAST once, maybe more if you need to. Then drain it and get some GOOD spa cleaner from the pool store. When you drain it don't bother cleaning the filter a final time. Throw it out and buy a fresh one. Now it's time to start scrubbing your brains out. Scrub every inch of the shell with the cleaner while rinsing it. If you're having trouble getting motivated, just imagine what might have been done in the spa in the past! -
Once a spa runs out of bromine and gets cant-see-the-bottom-cloudy (FYI this is happening in a matter of hours, usually after it gets used while low on bromine) is there any easy way to clear that water up? Or is it just easier at that point to drain it and put fresh water?
Any word on the quality of Waterways? I've actually already found their product online and was thinking of using it, but I don't want to end up buying the same crap I already have.
Had it 4 years. First year I wasn't really into it, but I've used it almost every day the last 3 and love it.
I have a Pro-Form Storm hot tub that is about 4 years old. It's been a complete piece of garbage and a total waste of money with everything that's gone wrong with it and the lack of customer support. But, it's what I got and I'm trying to work with it. The worst part about it is the jets. They constantly break. The inserts pop out of the housings, they seize up and stop spinning, they won't shut off when you twist them, they are disintegrating, etc etc etc. Every day I find more of these little plastic teeth in the bottom and I have no idea where they are coming from. I already had to hack the thing up and install a ghetto valve to shut off the neck jets so they didn't shoot fierce high pressure water from above the water line rendering pump #2 unusable. I am interested in re-jetting the entire spa with a different brand or style of jets and housings. Any advice on good quality parts? I would like to be able to manually control each one by twisting it to shut it off and NOT have it fall apart in 6 months like every replacement jet ever sent to me from Pro Form.
