JOHN C SIMON Posted March 12, 2008 Report Share Posted March 12, 2008 I AM BUILDING A CONCRETE POOL AND SPA, I AM A PLUMBING AND ELECTRICAL CONTRACTOR NOT A POOL PLUMBER. WE ARE INSTALLING JETS AT 6 LOCATIONS, BUT CURRENTLY THEY ARE AT THE SAME HEIGHT IN RELATION TO THE SEAT. CAN SOMEONE TELL ME IF I SHOULD VARY THE LOCATIONS TO HIT THE UPPER AND LOWER BACK LOCATION? ALSO WE HAVE INSTALLED THE JET TEES FOR PENTAIR AND I AM DEBATING ON WETHER TO TEAR THEM OUT AND GO TO WATERWAY. ARE THEY THAT MUCH BETTER THEN THE REST. ONCE ITS DONE AM I GOING TO REGRET NOT RELOCATING THE JETS. THANK YOU Quote Link to comment Share on other sites More sharing options...
don pool Posted March 12, 2008 Report Share Posted March 12, 2008 It would be best to vary the height of your jets, but if you don't want to change the plumbing you could have the gunite guys vary the height of the bench in the spa to allow you to have the jets hot your back at different levels. Quote Link to comment Share on other sites More sharing options...
drip Posted March 14, 2008 Report Share Posted March 14, 2008 I like waterway better than pentair for spa jets. They are making some now that are a 4 jet manifold that would supply one person, 2 on upper back and 2 on lower. I havent seen them in use yet, they are pretty new but it will probably be the standard before too long. I wouldn't tear out the pentair ones only to put in basic waterways either and usually all the jets in a gunite spa are at the same level, the seat height will sometimes be manipulated, but it is pretty rare. Quote Link to comment Share on other sites More sharing options...
Discountpoolspa Posted March 25, 2008 Report Share Posted March 25, 2008 I like the waterway jets better as well, but it may not be worth it to tear anything out. As for varying height of the jets, I try to stay away from varying more than just slightly. It seems that if you vary the height much, some of the jets will get much better air flow than others. I would contour the bench instead of moving the jet. Quote Link to comment Share on other sites More sharing options...
