Hot Tub In Basement?
We are in the market to purchase a home. We found one that has a 6 person hot tub in the basement. The basement is a daylight basement as opposed to a walk-out basement. I'm not sure how they even got the hot tub in there!
My question(s): Is a hot tub in the basement a good idea?
Will a hot tub in the basement cause rust and more humidity that can't be controlled?
Any ideas how to get it OUT of the basement? I think they cut an area between two of the daylight windows and slid it in there. There seems to be evidence of patching on the wall around and by the windows. I'm assuming this would be very expensive to reverse the process and take it out the same way.
Are we looking at more trouble than we want if we purchase with the hot tub in the basement?
Help ... any ideas?
Help ... any ideas?
Humidity can be controlled with exhaust fans. Over time there may be problems with staining on sheet rock and stuff. But if you controll the steam it can be done. More important is draining, theres almost always splash. And what about draining the tub, do they have that covered? Getting it out or a new one in.....yea good one, between 2 windows and some demo and concrete patch. It's funny they don't just support the upper floor on both sides and make the removable area wood, or doors. But it can and obviously was done. If it's a good quality tub it should last 15-20 years so it's not like you have to do it that often. I'd have to look at it to give you an idea of what I would charge to do it. I have done it before but it was a walkout that we removed the sliding glass door to accomplish it.
Next question for you is why? The stars at night are awsome from a 102 degree tub! :)
Help ... any ideas?
Help ... any ideas?
Thanks for responding. I'm not really sure how to use this site, so I hope I'm doing it right.
There are no fans in the basement at this time. Draining is not a problem. They have a sump pump to drain into. I'm not sure what you meant by "It's funny they don't just support the upper floor on both sides and make the removable area wood, or doors. But it can and obviously was done. " The hot tub seems to be on a platform of some sort, but that's all. The floor underneath is tile and has some stains around the tub (rust???) I'd love to have it outside, but we are trying to keep our costs down and I think building the platform outside, replumbing & rewiring, then addding a privacy fence is more than what we want to incur at this time.
If you are in the market to buy this home and there is no exhaust fans i would ask how long it had been down there and if it were me would consider having an inspection done for mold/moisture damage just in case. Although it might be less in a heated basement, a spa gives off a lot of moisture. I think a heavy duty exhaust system would be a must with an installation under a living area. good luck.
