Showing results for tags 'PUMP'.
Hey guys, I finally got my Vita Spa Vintage LH hooked up and filled up but have a few problems. First no heat, no heat indicator lights and the high limit switch isnt tripped (checked to see if the lil red button had popped) Secondly, when i flipped the breaker the bubbler kicked in automatically, but the pump for the jets wasnt running. It only runs when I hit the Jet button on the control panel, and the jets arent working. Tried the 3 valves but no luck. My control panel has the old style temp dial with a button for jets,blower,and light. They all have indicator lights at the top. Any ideas?
Hello, I have a Hayward Super II Pump SP3010X15AZ that is leaking from the top. I had a pool professional look at it and they replaced the housing gasket. It was still leaking after they replaced the gasket and then indicated that the seal plate may be cracked. In looking at where it is leaking and researching on the internet everything I have read still points to the gasket as being the issue. It is leaking from the top, between the seal plate and the pump housing. Before I order parts I wanted to see if someone could provide me with an educated guess if I should order the seal plate and another gasket? Or could something else be causing this leak? Thank you!
I have a Polaris PB4-60 Booster pump that I recently unhooked from everything to put a new seal in as it was leaking. After I re-installed it just the way it was and turned it on it made a lower sound than normal then tripped the breaker. I checked the wiring and tightened the grounds and tried again, it ran for a moment (I could see the cleaner's hose tighten up like it does normally) and then it tripped again. This time though I noticed a almost burning smell was coming from the pump so i left it alone for a day or two. I came back today and tried it again and it did the same thing after no more than ten seconds, I did notice even after that short of a time that the outer metal of it was pretty warm for running that short of a time. Is there anything I can do to save this pump, or is it time to replace some part or the whole thing?
