Hello,
I have a Hayward Super II Pump SP3010X15AZ that is leaking from the top. I had a pool professional look at it and they replaced the housing gasket. It was still leaking after they replaced the gasket and then indicated that the seal plate may be cracked. In looking at where it is leaking and researching on the internet everything I have read still points to the gasket as being the issue. It is leaking from the top, between the seal plate and the pump housing. Before I order parts I wanted to see if someone could provide me with an educated guess if I should order the seal plate and another gasket? Or could something else be causing this leak? Thank you!
