AJboy123
AJboy123's Achievements
  1. we figured out the jet problem.....we completely bypassed and put 240 to the element, light came on, no light on control panel and no heat so far......maybe thermostat?
  2. Hey guys, I finally got my Vita Spa Vintage LH hooked up and filled up but have a few problems. First no heat, no heat indicator lights and the high limit switch isnt tripped (checked to see if the lil red button had popped) Secondly, when i flipped the breaker the bubbler kicked in automatically, but the pump for the jets wasnt running. It only runs when I hit the Jet button on the control panel, and the jets arent working. Tried the 3 valves but no luck. My control panel has the old style temp dial with a button for jets,blower,and light. They all have indicator lights at the top. Any ideas?
  3. Hi all, im new to the forum. I recently purchased a Vita Spa Vintage hot tub with a heat problem. I believe the element is bad but not to sure. After removing it I did an ohms reading and got .17 ohms. I checked Spa Depots website before I found this forum and they said most elements range from 9-12 ohms if they are good, and some can go up to 25 ohms. So far the high limit and thermostat tested good so im leaning towards the element. Its a 240v and from what the element cover says is 6000 watts. Any help would greatly be appreciated! Also is there any way to test the thermocouple? From what I can see i has 1 wire going directly to the high limit.
