Amber Watson
  • Gender
    Female
Amber Watson's Achievements
  1. Hi Asfyxiate, I think this will be a great answer to your question. When you vacuum your pool, it must always be set to "FILTER" Unless if the pool is extremely dirty, it might be a better idea to "vacuum out to waste" instead. This is where you set the filter to the "WASTE" setting before vacuuming, causing the system to bypass the filter and remove the water from the pool. Hope this helps...
  2. Hi sunjunky, I just want to give you some advice about your problem. The stains in the pool are not caused by the rusting bands of your Vio Turbo pool cleaner. It is because the salt in the water can cause rusting, especially in pools that are converted from typical water to salt. It is the salt from the water that causes all the rust stains to your swimming pool even to your pool cleaner. I recommend that you seal your pool steps to prevent rusting. you can use protective and restorative products to seal off the steps so that this doesn't happen year after year. This salt water pool care tip is best done at the end of the swimming season, when you can partially drain your pool in order to apply the sealant.
  3. I think it's not covered in the warranty, but you can complain it to them.
  4. HI swimz4us, Just want to give some ideas on your project. Give some catalogs. This is for the heater WO200 - Made to fit Teledyne Laars, Anthony, Comfortzone, Raypak 175,000 BTU - 265,000 BTU WO200H - Made to fit Hayward H Series Models 150, 200, 250, and Sta-Rite Max-E-Therm WO200M - Made to fit Purex-Triton Minimax Models 150, 200, 250 WO400 - Made to fit Teledyne Laars, Anthony, Comfortzone, Raypak 325,000 BTU - 400,000 BTU WO400H - Made to fit Hayward H Series - 300, 350, 400 WO400M - Made to fit Purex Triton MiniMax Models 300, 350 & 400 for the salt system I'll recommend Zodiac Clearwater LM2-40 Replace Cell for the pump Super Max 1.5 HP Pump You should follow what you want. Believe in yourself. Goodluck!
  5. Well, for me I like the Sundance Hartfort Series 680. I thinks it's more reliable because it's the newest. Yes dear, 5 year old is old enough.
