Hey guys, here's a tricky one that's been mind boggling, it's more about the hot tubs than the pool, but...
I run an inground pool as well as 2 inground hot tubs. The flow rate on the hot tub use to be 100 GPM. With about 10 PSI on the sand filter. I've recently noticed that it's actually gone down to 75 GPM, and still 10 PSI. So I did a backwash, cleaned out the skimmer baskets as well as the strainer basket at the pump. None of which were terribly dirty. At this point I've noticed the skimmers have next to no suction. I changed the multiport valve to re-circulate and the flow rate went up to 120 GPM, so I decided to let that sit overnight. The next morning I found that the flow rate is down to about 30 GPM. I switched back to Filtering and currently have 0 flow, and 3-5 PSI.
Any insight on what is happening?
***Edit***
Also I meant to mention that bubbles are visible from the return jets.
