Timo0803 Posted March 12, 2012 Report Posted March 12, 2012 Hi, Could please somebody explain me the definition in the Australian Standard AS /NZS 1839:1994 about the Final Level of the Pool: Final level of pool …The finished pool shall be level to within 1/225 of the overall length of the wall being considered up to a maximum of 1/300 of the overall length (l) of the pool. I am trying to understand this definition in regards to our own pool as there is a max. height difference from water level to upper pool shell of 30mm. The total length of the pool is 8.5m. Thanks. Timo Quote
PoolGuyNJ Posted April 17, 2012 Report Posted April 17, 2012 It sounds like to me, and I could be wrong, like your pool is 8500 mm in length. For each width of wall that is 1/300 of that length or 28 and a third millimeters wide, the height shall not vary by more than 37.77 mm. Math used: 8500 mm in length divided by 300 = the length of the section being measured = 28-1/3 mm 8500 mm divided by 225 (the max per section of variance allowed) = 37.77 mm variance Seems like a lot though. The only other way I could interpret that would be to divide the 28-1/3 by 225 but that's only a .168 mm variance and that seems like a very small number, almost impossible to measure without very precise instruments. Scott Quote
