Tiger River Spa Manora
  • Please log in to reply
7 replies to this topic
#1 casterjack
casterjack
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 04 November 2009 - 04:01 PM
i have a 95 tiger river manora spa that was working now it has a flashing power light. I have jumped the relays and the light heater both pumps work. I have replaced one of the sensor plug into the heater does anyone else know what else it could be?
thanks
casterjack
#2 sunken soaker
sunken soaker
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 10 November 2009 - 08:23 AM
I'm having a simular problem. Same tub. Replaced the heater that was cracked and leaking with a Watkins lo flo heater assy 1.5/6K. Power light blinking red, no flow. Jumped flow sensor, and high heat sensor.- Didn't work. Burr it's cold!
#3 hottubdan
hottubdan
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 447 posts
Posted 10 November 2009 - 08:35 AM
QUOTE (sunken soaker @ Nov 10 2009, 08:23 AM) <{POST_SNAPBACK}>
Flow issue? Clogged filter? Circ pump?
#4 sunken soaker
sunken soaker
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 10 November 2009 - 09:07 AM
QUOTE (hottubdan @ Nov 10 2009, 08:35 AM) <{POST_SNAPBACK}>
Filter clean, circ pump 6 mo. old worked fine with old leaking heater.
#5 Peteyboy
Peteyboy
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 460 posts
  • Gender:Male
Posted 10 November 2009 - 11:43 AM
QUOTE (casterjack @ Nov 4 2009, 04:01 PM) <{POST_SNAPBACK}>
Do you know which sensor you replaced? The one with the smaller threads is the one that is probably the culprit. I think it's the middle plug on the control box.
spas are electrical devices and can be dangerous to repair - please use this advice at your own risk
Pete
Spa Tech since 1987
Spa Repair Services
Indialantic, FL
#6 casterjack
casterjack
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 10 November 2009 - 06:30 PM
QUOTE (Peteyboy @ Nov 10 2009, 12:43 PM) <{POST_SNAPBACK}>
i have replaced both of them now high limit and i believe the flow sensor. on the power board I am not getting any power past the transformer but it ohms out ok i now supect the transform is not getting the signal to kick on to drive the relays leet me know if i am wrong in this line of thinking?
thanks
Jason
#7 Peteyboy
Peteyboy
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 460 posts
  • Gender:Male
Posted 11 November 2009 - 11:30 AM
Test AC voltage at the black & white connection on the circuit board next to the transformer - 110V. Then test DC voltage at J4 pins 3 & 4 (should be the 2 orange wires) these are the output to the circ pump relay coil. If you have voltage there the board is probably OK.
I believe that year had a reset by turning down then up the thermostat.
Pete
Spa Tech since 1987
Spa Repair Services
Indialantic, FL
#8 casterjack
casterjack
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 11 November 2009 - 02:33 PM
QUOTE (Peteyboy @ Nov 11 2009, 12:30 PM) <{POST_SNAPBACK}>
i dont know if it was the reset or me finding a wasp nest under the transformer and cleaning it out but the light is staying on now but the jet pump is not turning on any suggestions on that it is getting dark here now so i will have to check it out tomorrow
thank you
Jason
