chisca Posted May 16, 2008 Report Posted May 16, 2008 My inground vinyl liner pool (as I've posted previously) is special, as in there are no longer any replacement parts available! The new problem I have run into is replacing the faceplate for the skimmer. The opening to our skimmer is rather odd shaped, it's slimmer than the standard faceplate. As sort of a band aid approach I guess, the previous home owners took a standard faceplate, and cut the top off to make it fit. It looks rather silly, and obvious. Does anyone know where I can get a faceplate replacement that isn't standard? I've looked, but can only find faceplates that would fit a normal pool, and there is nothing normal about our pool, as we are quickly finding out. Quote
Pathfinder Posted May 16, 2008 Report Posted May 16, 2008 Post a pic of the skimmer if you could. Also the lid covering from the deck is it original or replacement. If its original look on the under side for a manufacture name or serial #. Quote
