Sundance Control Panel Going Wacko
goldy
I need help! I have a 1999 Sundance Montego, and I shut it off today to refill it, and when I turned it back on, the control panel looked like it was working fine. I went to push the temp up button, and it freaked out, and went blank. I turned it off and restarted it, and it blinked a whole bunch of random numbers and then went black again. It is cycling and pumps work, but you have to press the wrong buttons to get them to come on and there is no temp display. Is this the control panel that needs to be replaced or something else????
Goldy
Goldy
If you have to press the wrong buttons to get the pumps to work, it sounds like a bad control panel.
Goldy
It sounds very much like it is the control panel. It could also be the circuit board, but that is not likely based on the description of what the tub is doing.
