Tom in Colorado Posted July 2, 2007 Report Share Posted July 2, 2007 I recently bought a new home with an Elite Platinum hot tub. I turned off the power at the breaker, drained and then refilled the tub. When I turned the power back on, pump 2 surges on and then off repeatedly. I'm pretty sure that I need to bleed the system, but I have no idea where to start. Any suggestions would be greatly appreciated. Thank you. Quote Link to comment Share on other sites More sharing options...
Jim_The_Jim Posted July 2, 2007 Report Share Posted July 2, 2007 I recently bought a new home with an Elite Platinum hot tub. I turned off the power at the breaker, drained and then refilled the tub. When I turned the power back on, pump 2 surges on and then off repeatedly. I'm pretty sure that I need to bleed the system, but I have no idea where to start. Any suggestions would be greatly appreciated. Thank you. Did you fill the tub from the filter housing? Is the water way above the upper intake so no air can be drawn in? It the motor going on and off or is it just the water flow?` Quote Link to comment Share on other sites More sharing options...
ChandOne Posted July 5, 2007 Report Share Posted July 5, 2007 I recently bought a new home with an Elite Platinum hot tub. I turned off the power at the breaker, drained and then refilled the tub. When I turned the power back on, pump 2 surges on and then off repeatedly. I'm pretty sure that I need to bleed the system, but I have no idea where to start. Any suggestions would be greatly appreciated. Thank you. I'm not sure about your spa, but on mine there are bleeder screws on top of the pump and filter. It should be a pretty large screw, probably metal, and located right on top of the wider part of the pump. With the jets running on low, back the screw out a bit until you hear the hiss of escaping air. Once that turns to water, tighten the screw. You may need to repeat a few times, and sometimes switching from high to low jets will push some more air out Quote Link to comment Share on other sites More sharing options...
