Bigbaddewulf Posted March 11 Report Share Posted March 11 Hello. Anyone know if it’s possible to connect a heat pump relay to the gecko controller relay so that it can control my heat pump. Currently I get a flow error on my heat pump when the filter pump is off. As soon as the filter pump starts the flow error goes away and the heat pump starts working. I want to control via the IN.GRID but apparently that is only possible on a IN.YJ-V3 with unified core software. Trying to find a better solution than relying on the flow error to stop the heat pump as not sure if this will cause other issues. Quote Link to comment Share on other sites More sharing options...
