Hotspring remote malfunction -- Yes to connect new spa not responding
Bob782
I've looked around and not seen this problem mentioned.
I am trying to connect my remote after removing and replacing the [same] battery.
I get to a screen that asks if I want to Connect a New Spa [which is what I want to do]. There is a bright Yes button and a dark No button. And the instruction at the bottom to touch and hold the screen if I want to calibrate the screen.
If I try to touch the yes button to connect a new spa nothing happens. If I hold touch the yes button for too long it takes me to the calibrate screen. Then small buttons appear sequentially in the four corners and I can touch them and then it takes me back to the Connect a New Spa screen.
But I am unable to get the Yes button to respond.
Turned spa off and on a few time. I've taken battery out and in a few times. Spa is operational and the temperature seems right.
The remote is barely one year old -- purchased Dec 2021 -- and treated gently by adults and not ever in the water.
Any suggestions ?
On a related note is it possible to check to see if the battery is charged sufficiently ? I there a way to measure the voltage available ?
I imagine the spa has to be talking to the remote to get the buttons to respond. Is there a way to determine if the spa is the culprit [as opposed to the remote]
I live a a rather remote area. Getting a [reliable] repair person to respond can be a challenge.
Thanks.
