LeakyBlinders Posted February 12, 2023 Report Share Posted February 12, 2023 I’ve got an issue where my spa is draining but it’s actually draining BELOW the pool water equilibrium line! I can’t figure out where it’s going. I had the system checked for leaks a few weeks ago and I don’t feel like they were able to identify why this was happening. They said it’s somehow leaking into the pool and going out of the overflow. But how can that be when the spa water level is far below the pool overflow and the pool water stays level? I turned the whole system off and the spa lost about 3-6 inches of water a day until it was about completely empty. The pool water level stayed the same the whole time. It didn’t even reach the bottom of the overflow port. I’ve replaced the back-flow sting/flap unit and it didn’t help. I’m hoping it’s not an underground leak! But I had it all pressure tested and they said the pipes aren’t losing any water. They There is an air leak in the pipe near the Main drain valve that they said may be sucking in some air but it’s not losing water. Help me get my water bill under control! Quote Link to comment Share on other sites More sharing options...
