Paula morris Posted May 1, 2021 Report Posted May 1, 2021 I have layz Vegas and today it is flat as a pancake. When I try to reinflate the air comes out of the bubble skirt and the hot tub won’t inflate. is it dead ? Quote
RickW Posted May 17, 2021 Report Posted May 17, 2021 Hi Paula Did you manage to get this sorted? I have the same issue. Thanks Rick Quote
Paula morris Posted May 17, 2021 Author Report Posted May 17, 2021 No I didn't I have raised it with Layzspa, but I have only 6 months warranty and I have had the spa for 8 months ,so not holding out too much hope, also you are the only one that replied How long have you had yours? Quote
Phill Posted August 10, 2021 Report Posted August 10, 2021 On 5/17/2021 at 2:18 PM, Paula morris said: No I didn't I have raised it with Layzspa, but I have only 6 months warranty and I have had the spa for 8 months ,so not holding out too much hope, also you are the only one that replied How long have you had yours? Hi Paula. if it’s a small hole say 1” you can fill the tub with water way over the bubble skirt until the bubble skirt fills with water. then try inflating tub, the pressure of the water usually stops the air leak unless the hole is really big. Hope this has helped. Quote
Colin-C Posted September 21, 2021 Report Posted September 21, 2021 Did you guys ever sort this, I have the exact model with the exact issue, turning on the jets inflates the hole thing to the point were its dangerous for the rest of the seems, its currently unusable, I can tell exactly were the hole is, i was going to repair it myself but after seeing this post, I wont because its still under warranty and by the sounds of it is a defect. Quote
chelle Posted May 30, 2023 Report Posted May 30, 2023 I have the exact same problem with the Vegas only seems to have happened after repairing a rip on the liner Quote
chelle Posted June 2, 2023 Report Posted June 2, 2023 Update- Spoke to a guy who services hot tubs and he says this is not repairable unfortunately Quote
