Fixing 5.0 ppm CC in hot tub?
DougA
I have a 400 g. hot tub with Nature2, MPS and occasional adds of bleach because CYA is high (100 ppm).  My combined chlorine is 5.0 in my hot tub.  Free chlorine is a 2.0.  Can I fix the combined chlorine with MPS?  If so, how much should I use?
Any other recommendations.
Thanks!  Doug
  • 1 month later...
Your CYA is way too high.  WIth a CYA of 100 you will need to maintain a FC level of 8-13 to keep it sanitized and will have to raise it to 39 to shock it.  I would started by draining atleast 2/3's of the water out to get the CYA down to 30 or so.  If it were me...I would drain it all and start over.
