brownmola Posted April 19, 2019 Report Share Posted April 19, 2019 I was told that my TX was plumbed for ozone and I expected to see a venturi injector that I could just hook up the ozone tubing to. I don't see that. I think I have to cut a water line and add my own venturi injector to then add my ozone set up. Can anyone direct me as to which water line needs cutting for the venturi injector? There is a sticker inside that has some cutting instructions but the sticker was just on the ground instead of the tube it probably originally was attached to. Thanks. Quote Link to comment Share on other sites More sharing options...
davemill Posted August 8, 2019 Report Share Posted August 8, 2019 You are better off contacting the manufacturer for the precise location to cut, but here's a general answer: Ozone generators have two parts: The generator itself, which just generates ozone but does not pump it, and a venturi injector, which inserts into your water flow and sucks the ozone out of the generator. There is a good diagram on this page. http://www.hottubcoverpros.com/should-i-use-an-ozonator-to-prolong-the-life-of-my-cover/ Quote Link to comment Share on other sites More sharing options...
Peteyboy Posted September 22, 2019 Report Share Posted September 22, 2019 I wouldn't add ozone to the TX unless you retro it to a circulation pump system. You would have to run the spa too long for the ozone to be effective. Quote Link to comment Share on other sites More sharing options...
