Gecko aeware in.k600 control panel
Xborda
I'm hoping someone can help me here, one of my kids has messed about with the control panel on my hot tub, its a "Gecko AEWare IN.K600", and I have the Gecko IN.XM spa pack.  They've managed to select the "Keypad upgrade" option in the info sub menu.  When I opened the lid the display read "Bootloader Software Upgrading" (could've been like this for a day or so) I cancelled the upgrade, and now the control panel only has the option to turn on the light, (although it doesn't turn on)  Usually it has the light icon at the top then 3 jet options below it.  I can access the "options" menu and the "info" sub menu, also I can set the region, security and time and date and set the temperature of the water, although the water doesn't heat up.
I've tried turning it off at the supply isolator and turning it back on, also been through the IN.XM LL program on the spa pack and this didn't appear to flag up any error codes.  I've also tried the keypad upgrade option again but it just stayed on the bootloader software upgrading screen until I cancelled it.
Does anybody know if there is and option to roll back the software, or factory default it?
The only info I can find on software upgrading is using an in.stik in the spa pack.
Any help or guidance would be much appreciated
Thanks in advance
Dave
