Xborda Posted September 29, 2018 Report Share Posted September 29, 2018 I'm hoping someone can help me here, one of my kids has messed about with the control panel on my hot tub, its a "Gecko AEWare IN.K600", and I have the Gecko IN.XM spa pack. They've managed to select the "Keypad upgrade" option in the info sub menu. When I opened the lid the display read "Bootloader Software Upgrading" (could've been like this for a day or so) I cancelled the upgrade, and now the control panel only has the option to turn on the light, (although it doesn't turn on) Usually it has the light icon at the top then 3 jet options below it. I can access the "options" menu and the "info" sub menu, also I can set the region, security and time and date and set the temperature of the water, although the water doesn't heat up. I've tried turning it off at the supply isolator and turning it back on, also been through the IN.XM LL program on the spa pack and this didn't appear to flag up any error codes. I've also tried the keypad upgrade option again but it just stayed on the bootloader software upgrading screen until I cancelled it. Does anybody know if there is and option to roll back the software, or factory default it? The only info I can find on software upgrading is using an in.stik in the spa pack. Any help or guidance would be much appreciated Thanks in advance Dave Quote Link to comment Share on other sites More sharing options...
Xborda Posted October 1, 2018 Author Report Share Posted October 1, 2018 Sorted the issue, spoke to technical services at arctic spas and they talked me through selecting the correct program on the spa pack, only took 5 mins! I’m back in the game! Quote Link to comment Share on other sites More sharing options...
