Leisure Bay Spa no Jets....
Ok so my wife and I inherited a 2004 Leisure Bay Spa Model #102SRCS3 from her mother when she passed away.  I built a platform to make it level and ran power from my circuit panel to the spa.  I replaced the GFCI plug as well.  I plug it in and control panel comes on and says Pr then —F which according to the manual is normal. The filter then starts sucking water and blowing it back into the spa from the port directly above the filter suction.  After about 10 minutes or so I can adjust the temperature settings up and down and change the mode from standard to economy and sleep mode and back.
My problem however is I can not get any of the Jets to function.  I have turned them all on and off several times.  When I press the pump button either nothing happens at all or it will display F1L4
My knowledge on spa is extremely limited but would like to get this diagnosed correctly before spending money on a new pump motor.  Thanks again for any assistance.
wont allow me to add any pictures unfortunately
