K9powered Posted September 3, 2017 Report Share Posted September 3, 2017 I bought a new Hotspring TX (140 gal) in July. It came with the Nature 2 cartridge, an ozone system and a starter kit of chemicals. I purchased the K2006 test kit after using the test strips that came with the tub. They suck!! Since day 1 I felt like it was using too much chlorine. I would need to add clorine evrey day, even when no one used the tub just to keep the level fro dropping to zero. So after about 21 days, I had a high CYA level I decided to purge the system and do a refill. Now 28 days later my CYA level is up to 100. Last night I drained it and did a refill (no purge). Dealer is of no help, they tell me I need to use more MPS, and I think I am allergic to it. The routine the dealer wanted me to use was as follows... Before each use rotate between 1TBSP of Oxidizer and 1/2 TSP of Chlorine. The label on the Oxidezer says use 1 TBSP once a week in 200 gallons!! I don't know what effects too much Oxidezer has on the water, but my skin didn't like it. I then just statted using it once a week and that issue went away.TA, CH, and PH were all in the recomended range. I admit I am a newbie but I think the dealer really sent me down the wrong road..i have some experience with the k2006 test kit and pools at my job, but not hot tubs. I have been reading about the bleach method and I think that is my answer, but the owners manual for the tub specifically says not to use bleach or any sodium hypochlorite product. I am concerned about voiding my warranty and or damaging my tub. Could there be some hidden reason that this method will hurt my tub? I really don't want to drain this tub evrey month. Any help you guys can give me would be much appreciated, thanks in advance!! Quote Link to comment Share on other sites More sharing options...
