premiumleisure Posted April 15, 2017 Report Share Posted April 15, 2017 Too many people are regretting purchasing a spa tub, because they didn’t make sure that they are purchasing a high quality one. And, this makes people hesitant to purchase these spa tubs. However, if you are going to make sure that you know this buying guide of purchasing portable hot tub spas, you will not make a mistake in purchasing the wrong one. The one thing that you need to know is that there are many different types of spa tubs that you can purchase, and that you need to make sure that you take your time and find the right one. When you are following this buying guide, you will not need to worry about purchasing the wrong one: Research the brand as well as the spa Most people are doing research about the portable hot tub spas that they are considering purchasing, but they don’t do research about the brand of the spa. This can lead to all kinds of problems. It is really important that you should take the time and to research the spa and the name of the spa. So that you can know that you are going to purchase known name that will not give you all sorts or problems along the way. Reading reviews about the brand and the spa, is going to give you a better idea if this is a high quality spa tub that you are going to purchase. What size spa tub you need You need to make sure that you are purchasing the right size spa tub for your needs. But, also for the available space that you have. Most people prefer the four persons hot tub, but this might not be the right size for you. Especially, if you are a large family. So, make sure that you are going to consider the size of the tub, beforehand. You also need to know that most tub spas are taking up a lot of space, so you need to make sure that you consider the size that you have available for your spa that you’re going to purchase. Talking to friends and family If you know family and friends, that have purchased their own portable hot tub spa, you can talk to them and hear which one they are recommended to you. Just kept in mind that their preferences might not be what you want and need. Don’t purchase the one they tell you to purchase, but take in consideration about what they have experienced when they purchased their spa tub. You can take their experience, and make sure that you purchase a better one, or a higher quality one for you and your household. The price of the tub and the equipment included Some spas might look a lot cheaper than other four person hot tubs that you can purchase. But, they are cheap because you might need to purchase some necessary equipment separately. And, if you have done your research, you will know what equipment you need to install the tub in your home. You need to look at the price of the tub and make sure that you are going to know what are going to be included with the tub. Then, you will know if you are going to get value for money, or if you are going to find yourself, paying more, because you need to buy equipment separately. Ending up costing you a lot of money. The warrantee You might think that when you purchase a portable hot tub spa, that you are going to get a warrantee included. However, this isn’t the case. There are many companies that don’t add a warrantee to their tub spas, and you are going to struggle when the tub breaks or have a malfunction. Make sure that you are getting a warrantee with your purchase. There is no reason why you should purchase the wrong four person hot tub and regretting the purchase. If you are following and remembering these tips, you are going to be sure that you are going to purchase one of the best spa tubs on the market. And, then you are going to enjoy hours and hours of fun, in your tub spa. Resource By : https://www.prlog.org/12633448-dont-purchase-the-wrong-portable-hot-tub-spas-follow-this-buying-guide.html Quote Link to comment Share on other sites More sharing options...
Sebastian Hay Posted April 15, 2017 Report Share Posted April 15, 2017 thanks for sharing..great info Quote Link to comment Share on other sites More sharing options...
