LakeBumKyle Posted January 26, 2017 Report Share Posted January 26, 2017 I bought a used 2008 Limelight Pulse knowing it had a issue with the LED Lighting. The previous owner had a spa tech replace some of the led's and sockets already. I have read on some previous post that it is best to just go ahead and replace them all so I replaced the rest of the "points of light" that were not already done. While pulling the old lights I noticed that a few had condensation inside and behind the bulb. I blew all the sockets out with an air hose before putting the new light in. I have 5.5 VDC coming out of the power supply so the next thing to replace is the controller. Any other things I can try? Quote Link to comment Share on other sites More sharing options...
LakeBumKyle Posted January 30, 2017 Author Report Share Posted January 30, 2017 Update: I replaced the controller and now the topside corner rings, waterfall light and 8 of the tub lights work but I can only sometimes access the light menu from the control panel and it will lock up after the second or third color option. Quote Link to comment Share on other sites More sharing options...
Gwells67 Posted October 1, 2018 Report Share Posted October 1, 2018 You have bulbs in the remaining housings that have gotten wet and are shorting out. You need to replace the rest of the housings or at least take out all of the remaining bulbs. Quote Link to comment Share on other sites More sharing options...
