taruntyagi14 Posted December 23, 2015 Report Share Posted December 23, 2015 Hello Guys, We have a in ground spa in our backyard. It has a cover also which retains water from either rain or just overnight dew. With time it gets heavier and to make it lighter I manually have to drain the water out of the cover. What has gone wrong with the cover ? Google suggest that I should get a new cover. Is that true ? Thank you so much for your time. Quote Link to comment Share on other sites More sharing options...
Dr. Spa Posted December 23, 2015 Report Share Posted December 23, 2015 Google is never wrong ;-) HOW, do you manually drain out the water. Also, where exacty is it accumulating (there's multipul layers of a cover and exaclt where it accumulates would determin what if anything can be done (as well as the cause). Quote Link to comment Share on other sites More sharing options...
taruntyagi14 Posted December 29, 2015 Author Report Share Posted December 29, 2015 Thank you for your reply Dr. Spa. There is a big zip around the periphery of the cover that I am using to drain the excess water out. The plastic cover inside the spa cover has also teared so the water is going inside. If you think that I will have to get a new spa cover I would love to hear any suggestions from you. Can I not cover the spa cover with something cheap as we are not using the SPA that much now a days ? Thank you again for your time. Google is never wrong ;-) HOW, do you manually drain out the water. Also, where exacty is it accumulating (there's multipul layers of a cover and exaclt where it accumulates would determin what if anything can be done (as well as the cause). Quote Link to comment Share on other sites More sharing options...
Barks507 Posted January 31, 2016 Report Share Posted January 31, 2016 Time for a new cover. Once the inner core of styrofoam is saturated with water it's game over. It is constantly absorbing moisture from water in spa. This happened to me. Quote Link to comment Share on other sites More sharing options...
