Spa Cover Retaining Water
taruntyagi14
Hello Guys,
We have a in ground spa in our backyard. It has a cover also which retains water from either rain or just overnight dew.
With time it gets heavier and to make it lighter I manually have to drain the water out of the cover.
What has gone wrong with the cover ?
Google suggest that I should get a new cover. Is that true ?
Thank you so much for your time.
Google is never wrong ;-)
HOW, do you manually drain out the water. Also, where exacty is it accumulating (there's multipul layers of a cover and exaclt where it accumulates would determin what if anything can be done (as well as the cause).
Thank you for your reply Dr. Spa.
There is a big zip around the periphery of the cover that I am using to drain the excess water out.
The plastic cover inside the spa cover has also teared so the water is going inside.
If you think that I will have to get a new spa cover I would love to hear any suggestions from you.
Can I not cover the spa cover with something cheap as we are not using the SPA that much now a days ?
Thank you again for your time.
  • 1 month later...
