John0908 Posted June 12, 2014 Report Share Posted June 12, 2014 Have been trying to find out more info on how to replace round filter discs/grids. The pool has 20 and I will be replacing all 20. Has anyone ever done this work before or know where I might be able to get help/info on how to replace them. Thanks for any help or info. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted June 14, 2014 Report Share Posted June 14, 2014 I think the hardest part will be locating the grids. Have you found any? Quote Link to comment Share on other sites More sharing options...
John0908 Posted June 15, 2014 Author Report Share Posted June 15, 2014 Yes a whole sale place I buy everything from has them in stock. I was able to also get a hold of the company that installed the filter system and pick their brains as to how to replace the grids. Its didn't look to hard but I wanted to be 100% before telling owner I can do the job. After I replace will post back here as to how and if it was easy or I had problems. That way if others want to know its here. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted June 15, 2014 Report Share Posted June 15, 2014 There are the grids (you have), spacers (they should be ok to use over). The hub with oring, the drive plate with oring(s), and the threaded shafts may need to be replaced, but you wont know till you get in there. Does the backwash valve still operate? Quote Link to comment Share on other sites More sharing options...
