Yunus Posted March 17, 2014 Report Share Posted March 17, 2014 Hi everyone, Following Nitro and WaterBear's advice has been fantastic and saved me time and money. I used to use Nitro's Chlorine directions for my hot tub but I use it much less than I used to and can't keep up the daily maintenance that it needs so I'm switching back to Bromine. I have the Taylor K-2006 kit to test my water and that's fine for everything except the Bromine. Is there a specific kit I can get to add Bromine or are there just a few regents I can buy, I'm hoping to not have to spend another $50 on the K-2106 only to find that 2 chemicals are different or something. Quote Link to comment Share on other sites More sharing options...
Spanky Posted March 18, 2014 Report Share Posted March 18, 2014 Keep using your K-2006 just multiply the result by 2.25 (1.0 on the test result = 2.25ppm Bromine) The only difference in the K-2106 is the FAS-DPD reagent is R-0872 which is the same as R-0871 but calibrated for the 2.25 multiplication factor Quote Link to comment Share on other sites More sharing options...
Yunus Posted March 18, 2014 Author Report Share Posted March 18, 2014 Keep using your K-2006 just multiply the result by 2.25 (1.0 on the test result = 2.25ppm Bromine) The only difference in the K-2106 is the FAS-DPD reagent is R-0872 which is the same as R-0871 but calibrated for the 2.25 multiplication factor Thats easy enough! Thanks for the info. Quote Link to comment Share on other sites More sharing options...
mrwrick Posted August 14, 2014 Report Share Posted August 14, 2014 Thanks from someone else who always this site to have the most down-to-earth practical help. Still learning, but it is getting easier. Quote Link to comment Share on other sites More sharing options...
